Parallel-NetCDF: A High Performance API for NetCDF File Access
Overview
Parallel-NetCDF is a library providing high-performance I/O while still maintaining file-format compatibility with Unidata's NetCDF.
NetCDF gives scientific programmers a space-efficient and portable means for storing data. However, it does so in a serial manner, making it difficult to achieve high I/O performance. By making some small changes to the API specified by NetCDF, we can use MPI-IO and its collective operations.
Download
Our latest release is 1.0.2. This is primarily a bugfix release, collecting all the fixes and improvements since 1.0.1. See the release announcement for more information
Test Releases: We currently have no test releases, but you can always find the latest code in our subversion repository.
Subversion Access
The Parallel-NetCDF project is now using Subversion for source-code management. With the change we can also provide read-only access to anyone interested.
svn co https://svn.mcs.anl.gov/repos/parallel-netcdf/trunk parallel-netcdf
The SSL fingerprint should be df:f5:37:b1:69:11:e0:63:d3:99:a8:e4:de:50:11:01:f5:73:dc:0a
After you've checked out the source, run 'aclocal && autoconf && autoheader' to generate the configure script.
Documentation
  • Our Parallel NetCDF API (postscript, 158k) document describes the API we are using. We have tweaked the programming interface to be more friendly to parallel i/o while maintaining file format compatibility with the serial version of NetCDF.
  • Our (SC2003 Paper about Parallel-NetCDF (PDF, 97k) discusses our library and presents some performance results.
  • Jianwei Li's presentation (PDF, 167k) from the SC2003 conference.
  • Unidata's serial NetCDF documentation sometimes comes in handy for comparision.
Tuning
A note about Large File Support
As of parallel-netcdf-0.9.2, we ship with support for "CDF-2" formated data. With this format, even 32 bit platforms can create netcdf datasets greater than 2GB in size. See the file README.large_files in the source tree for more information.
The maintainers of the serial NetCDF library added support for the CDF-2 format in netcdf-3.6.0. The support was based largely on work from Greg Sjaardema.
File and Variable Limits
Both Parallel-netCDF and NetCDF share limitations on file and variable sizes. More information can be found on the FileLimits page.
Required Software
Parallel-NetCDF requires an MPI implementation with MPI-IO support. Most MPI libraries have this nowadays. A parallel file system would also go a long way towards achieving highest performance.
Related Projects
Parallel-NetCDF makes use of several other technologies.
  • ROMIO, an implementation of MPI-IO, provides optimized collective and noncontiguous operations. It also provides an abstract interface for a large number of parallel file systems.
  • One of those file systems ROMIO supports is PVFS, a high performance parallel filesystem for linux clusters.
Mailing List
We discuss the design and use of the Parallel-NetCDF library on the parallel-netcdf@mcs.anl.gov mailing list. Anyone interested in developing or using parallel-netcdf is encouraged to join. Send mail to majordomo@mcs.anl.gov with the body subscribe parallel-netcdf.
You can broswe old mailing list messages at the parallel-netcdf mailing list archives
In the news
  • Forrest Hoffman wrote an article about Parallel-netCDF in the July 2004 issue of Linux Magazine.
  • The HDF group at NCSA ported a serial NetCDF code to one using Parallel-NetCDF. They posted a writeup a writeup of their efforts . It's a little old but does provide some additional information to supplement doc/porting_notes.txt
Project Members
  • Rob Latham, Rob Ross, Rajeev Thakur (Argonne National Lab)
  • Alok Choudhary, Wei-keng Liao (Northwestern University)
  • Jianwei Li (NWU, since graduated)
  • Bill Gropp (formerly ANL, now UIUC)
Citations
When referring to the Parallel-NetCDF project, please use our "permanent" URL: www.mcs.anl.gov/parallel-netcdf. The 'trac' or 'www-unix' URLs could change.
If you are looking for a reference to use in a published paper, please cite our SC2003 paper
