Parallel I/O Benchmarking Consortium
Introduction
Parallel I/O performance remains a weak point in most parallel computing
systems in use today. While research continues on parallel I/O solutions,
results that apply to real systems and important application workloads are
few and far between.
One way that the community can as a whole make progress in this direction is
through standardizing how we test systems. By testing in the same manner,
comparing performance results from different sources (both applications and
systems) is more meaningful.
A second way that the community can progress towards more effective
improvements is through identifying important workloads and providing test
applications that benchmark performance for these workloads. There is no
single workload that is "important" with respect to every system; however, by
creating or gathering a collection of test codes and clearly describing what
patterns these test codes exhibit, we can provide the community as a whole
with a set of reusable benchmarks that can serve as a starting point for
performance studies of new solutions.
Purpose
The purpose of the Parallel I/O Benchmarking Consortium is to provide a set of
benchmarks for use in characterizing the performance of a parallel I/O system.
A concise set will be used for obtaining an "at a glance" view of I/O system
performance, and an extended set will be provided for discovering regions of
poor performance within a large space of access characteristics. These tests
will follow a consistent testing methodology, defined by the consortium, to
help with comparing results across tests.
The test will not attempt to measure correctness of the underlying I/O
system implementation, nor will it attempt to "score" the I/O system to
aid in generation of a "Top 500 I/O systems" or the like.
We want to get everyone in the community involved. If you are interested,
please join our mailing list and make comments on the document and/or test
codes. If you have a test code that you would like to see become a part of
the test suite, please let us know. It is only though the involvement of a
wide range of groups that this can be a success.
Documents
The document describing the consortium's work is available in PDF format.
Test Suite
A small but growing collection of good parallel I/O benchmarks:
Project-hosted Tests:
Application I/O kernels:
I/O kernels capture the I/O workload of a given application without all the
associated science. Tuning I/O kernels should have a direct impact on overall application performance.
- An updated version of the FLASH-IO benchmark. Algorithmically identical
to the one below. Contains updates for newer versions of Parallel-NetCDF and
HDF5:
flash-argonne-20060913
- An adaptive-mesh refinement code from NERSC: Chombo I/O
- I/O kernel for The MADspec astronomy code:
MADbench2
- An I/O kernel for the combustion code S3D: S3D-IO
- The POP ocean model kernel: POP-IO
- A fusion code: GTC-IO
Other Tests:
Other Resources:
- Joachim Worringen's Perfbase (perfbase.tigris.org) can be helpful in
tracking and analyzing benchmark results. He actively seeks out users and
feedback, so give it a shot and let him know how well it works for you.
Mailing List
A mailing list has been created for discussion of parallel I/O benchmarking
consortium topics. The list can be joined by mailing to [email protected]
with the subject "subscribe pio-benchmark".
